My system is in Dual boot 1) Ubuntu 2) Windows 8. How can I uninstall Windows8 If I uninstall Windows8 would it affect my other partitions (Drive D,E).
tiayush
To "uninstall" Windows, simply format its partition. You can use various tools for that. Probably gparted would be easiest for you.
IMPORTANT: Make sure to copy the data which you want to preserve. Userspace by default is located in C:\Users\<Username>.
Afterwards, it is as simple as running # update-grub. Your other partitions will not be affected, however you need to make sure to mount them. This may include editing the /etc/fstab file accordingly. Linux will have no problem with NTFS (assuming that's the filesystem you use).
