Virtual Box had been already installed by:
sudo apt install virtualbox
Then I went on installing the extension pack:
sudo apt install virtualbox-ext-pack
This runs into the error:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  virtualbox-ext-pack
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/11,6 kB of archives.
After this operation, 127 kB of additional disk space will be used.
Preconfiguring packages ...
Selecting previously unselected package virtualbox-ext-pack.
(Reading database ... 169888 files and directories currently installed.)
Preparing to unpack .../virtualbox-ext-pack_5.1.34-0ubuntu1.17.10.2_all.deb ...
License has already been accepted.
Unpacking virtualbox-ext-pack (5.1.34-0ubuntu1.17.10.2) ...
Setting up virtualbox-ext-pack (5.1.34-0ubuntu1.17.10.2) ...
virtualbox-ext-pack: downloading: http://download.virtualbox.org/virtualbox/5.1.34/Oracle_VM_VirtualBox_Extension_Pack-5.1.34.vbox-extpack
The file will be downloaded into /usr/share/virtualbox-ext-pack
dpkg: error processing package virtualbox-ext-pack (--configure):
 subprocess installed post-installation script returned error exit status 4
 virtualbox-ext-pack
I already tried to reboot and re-install using 'apt purge ...'. Nevertheless the problem is still remains.
How to install Virtual Box's Extension Pack via default repository in Ubuntu 17.10?
I just noticed that the directory /usr/share/virtualbox-ext-pack is empty. On a reference system the folder contains the *.vbox-extpack file. Maybe this is a proxy problem here?
eDeviser
  • 2,149
  • 24
  • 37
When you run this command :
During installation , the virtualbox-ext-pack is downloaded from http://download.virtualbox.org/ with wget tools.
But as you said, you use proxy for apt and also you can't access the http://download.virtualbox.org/ site, without proxy (because of curl: (6) Could not resolve host: download.virtualbox.org output, in your comments).
So you should set a proxy on your terminal (not just for apt) with this commands:
export http_proxy='http://proxyserveraddress:port'
export https_proxy='https://proxyserveraddress:port'
After set proxy in terminal, your problem should be solved.
