If I create a new user test1 using the adduser/useradd command, how much space does Ubuntu assign to the test1 user?
What happens when I have 10 users on my system? Do all of them use the same amount of space?
Fabby
  • 35,017
The minimum amount of space a user needs is:
fab-root@fab-ux-predator:/home/test_user
$ du --human .
36K .
The maximum amount of space a user can take is 95% of the entire partition unless you set disk quotas per user or unless you change the number of reserved blocks to allow them to take more or less than 95%...
Fabby
  • 35,017
The standard setup is that the size of the directory /home/test1 is only limited by the size of the partition and its file system and the space allowed for standard users to access.
5% of the space in an ext4 file system is reserved for the system and for running tasks with elevated permissions.
See man mkfs.ext4,
-m reserved-blocks-percentage
Specify the percentage of the filesystem blocks reserved for the super-user. This avoids fragmentation, and allows root-owned daemons, such as syslogd(8), to continue to function correctly after non-privileged processes are prevented from writing to the filesystem. The default percentage is 5%.
sudodus
  • 47,684
