I want to set an environment variable from a bash script that I wrote. So I created a bash script and called it set.sh. Its content is as follows:
#!/bin/bash
export DEV_SRC="/home/m/mydata/sourecCode"
echo $DEV_SRC
When I run this script, the output is
But if I run this code on the same terminal that I ran the above script from,
echo $DEV_SRC
I cannot see any value, so I think the value is not exported.
Why is the value not exported?
Zanna
  • 72,312
mans
  • 207
By default bash creates a copy of the current environment, executes the script in this environment, then destroys the copy.
To execute a script in the current environment you should use this syntax:
. /home/m/mydata/sourecCode
echo $DEV_SRC
or
source /home/m/mydata/sourecCode
echo $DEV_SRC
Zanna
  • 72,312
Ova
  • 466
