So I tried to install Ubuntu on my Dell laptop and I wanted to create a separate partition. I took away some free space from another partition already created. The space was listed as unusable, so I reallocated all of it in the previous partition which I took from. Then I tried to boot into Windows to transfer my data from a partition so I can format it to install Ubuntu. The funny thing is, it won't boot. It keeps on loading, nothing happens. After a force shut down, it entered the repairing tool and I got an error, which said that I can shut down or I can go into advanced settings and the following text:
logfile\\?\GLOBALROOT\Device\HarddiskVolume2\Windows\System32\Logfiles\Srt\SrtTrail.txt
So I searched a bit through the common problems and I found some solved through cmd. I typed these:
bootrec.exe /rebuildbcd
bootrec.exe /fixmbr
bootrec.exe /fixboot
Still can't boot. Then I typed these in diskpart:
select disk 0
select partition 1
active
extend filesystem
Then again the 3 other bootrec commands listed above. Didn't work either. So I found another solution and typed:
bootrec rebuildbcd
rem didn't find any windows installations, not here, not above
bcdedit /export c:\bcdbackup
attrib c:\boot\bcd -h -r -s
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
rem found 2 windows installations, pressed Y for both
Now it tells me that the operating system has failed to start multiple times and I need to reinstall the it with an installation media, which I currently don't have, alongside this error: 0xc0000001. Tried to boot into Safe Mode. Same thing, it keeps on loading and nothing happens. I have Windows 10 and Windows 7 installed, so I can easily boot into Windows 7, if needed. There are also 3 partitions, only 2 of them visible in 7.
The main problem would be that I can't boot into Windows 10. What can I do?
fosslinux
  • 3,881
