11
I'm trying to debug a C++ application using GDB and the Qt Creator IDE. Every time the debugger stops on a breakpoint, Ubuntu (v 17.10) thinks the application is frozen and issues the dialog box with the warning that "{application} is not responding" with options to force quit or wait. Waiting only results in the same dialog popping up 5 seconds later. The debugger is unusable while the dialog box is open. Is there a way to disable this warning entirely in Ubuntu?
Note 1: just found this question which is very similar but with Java.
Note 2: This happens in Gnome3 but not Unity. A temporary work-around is to log in using the Unity desktop.
Note 3: It appears this has been fixed in Ubuntu 18.04 (GCC 7.3).
Carlton
  • 311
There is a gnome shell extension to disable the force close dialog. It isn't the best solution but it helps working around apps that "lock" the GUI.
Download this
Extract it to $HOME/.local/share/gnome-shell/extensions/disable-force-quit@fmuellner.gnome.org/
Reload Gnome with Alt+F2, r, enter (it won't kill your session / apps)
Open Tweaks, under Extensions, activate it.
boutch55555
  • 1,226
