I downloaded deb-creator-i386 and it seemed to install. It is supposed to be a GUI for compiling and packaging. After install it says in order to run or execute the program or app, I have to do that with a command in terminal. Tried use ./. Did not work. I am using Lubuntu 16.04.
pa4080
  • 30,621
Dani
Calling dpkg -i deb-creator-i386.deb directly is not good idea because of dependencies.
Better ways are:
sudo apt-get install ./deb-creator-i386.deb
and GDebI:
sudo apt-get install gdebi gdebi-common
sudo gdebi-gtk ./deb-creator-i386.deb # GUI
or
sudo gdebi ./deb-creator-i386.deb # from terminal
After installation you can find its executable with
dpkg -L deb-creator-i386 | grep bin
N0rbert
  • 103,263
You can install the deb file with apt in a terminal. Open a terminal an navigate to the foilder where the downloaded deb file was saved. Then install the deb file with the command:
palto
  • 496
To install a .deb file, open a terminal and type
sudo dpkg -i
drag the deb into the terminal and click enter
Aaahh
  • 143
Try typing this in the terminal,
sudo dpkg -i deb-creator-i386.deb
Then hit Enter.
afagarap
  • 316
