I have laptop MSI GP70 and I am able to boot installation from first USB stick and install it on second USB stick, then when I want to boot installed system from second USB drive I am unable to do so, even pressing F11 this drive is not listed in possible boot drives... on the other hand I am able to boot this USB on other laptop without UEFI and MSI stuff - any ideas how to boot this pendrive in MSI laptop?
additional: maybe if there were possibility to create EFI partition to boot system then it would solve problem?
Solution I had problem a problem getting into bios (DEL key but it's pure luck when to click to reach bios) it turned out that my 32GB SanDisk USB drive was HDD Drive and this option wasn't set in BIOS now it's ok - also I turned boot option from UEFI to LEGACY and it worked
Lorenz Keel
  • 9,511
quester
  • 151
I had problem a problem getting into bios (DEL key but it's pure luck when to click it to reach bios) it turned out that my 32GB SanDisk USB drive was "USB HDD Drive" instead of "USB Key" and this option wasn't set in BIOS now it's ok - also I turned boot option from UEFI to LEGACY and it worked
quester
  • 151
-2
Ah, a full USB installation, my old nemesis. Often times, when you install Ubuntu on a USB flash drive, it can screw up your Grub on your main hard drive (even when you tell it not too). A sure fire way to get a full installation on a USB flash drive with no hassle, damage, or issue, is to do it through a Virtual Box. Else it can be risky and time consuming. What could have happened is that it put Grub on the hard drive and it then points to the USB to boot it but it won't boot if you transfer it to another computer.
