I was installing opencl drivers and SDK from this site using shell scripts. I got unmet dependencies error. I tried the solution given in Unable to fix unmet dependencies, but it did not work for me. I am very new to Ubuntu.Kindly help. Output for
root@mcw-01:/home/user01/Desktop#sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... failed.
libicu-dev: Depends: libicu52 (=52.1-3ubuntu0.4) but 52.1-8 is installed
libicu52: Depends: libstdc++6 (>=4.9) but 4.8.4-2ubuntu1~14.04.3 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Furthermore, this problen also changed the display resolution. only low screen resolution (640 x 480) is available.
It seems you are running 14.04, but the page only says the SDK install script has been tested on 16.04. It is probably not compatible with 14.04 (it seems to install a version of libicu52 that depends on a version of libstdc++6 which is higher than the one in 14.04).
The only solution I see is to install it on a 16.04 system.
fkraiem
  • 12,813
