I wanted to use dual boot, but didn't have enough space on my C: drive to do so. So I bought an SSD (on Windows E:\) and here as sda2/sda3 and tried to install it there following the guide from this question.
Dual Boot Windows 10 and Linux Ubuntu on Separate Hard Drives
I do not have a GRUB menu screen when starting the computer and second because of that, I cannot boot into my Windows OS.
Medium /dev/sda: 698,7 GiB, 750156374016 Bytes, 1465149168 Sektoren
Einheiten: sectors von 1 * 512 = 512 Bytes
Sektorengröße (logisch/physisch): 512 Bytes / 512 Bytes
I/O Größe (minimal/optimal): 512 Bytes / 512 Bytes
Typ der Medienbezeichnung: dos
Medienkennung: 0xf9f466ac
Gerät Boot Start Ende Sektoren Größe Id Typ
/dev/sda1 2048 1338822655 1338820608 638,4G 7 HPFS/NTFS/exFAT
/dev/sda2 1338822656 1340092415 1269760 620M ef EFI (FAT-12/16/32)
/dev/sda3 * 1340092416 1465147391 125054976 59,6G 83 Linux
Medium /dev/sdb: 931,5 GiB, 1000204886016 Bytes, 1953525168 Sektoren
Sektorengröße (logisch/physisch): 512 Bytes / 4096 Bytes
I/O Größe (minimal/optimal): 4096 Bytes / 4096 Bytes
Medienkennung: 0x8599553d
/dev/sdb1 2048 1953521663 1953519616 931,5G 7 HPFS/NTFS/exFAT
Medium /dev/sdc: 232,9 GiB, 250059350016 Bytes, 488397168 Sektoren
Medienkennung: 0x626f7671
/dev/sdc1 2048 1026047 1024000 500M 7 HPFS/NTFS/exFAT
/dev/sdc2 * 1026048 487425945 486399898 232G 7 HPFS/NTFS/exFAT
/dev/sdc3 487426048 488390655 964608 471M 27 Hidden NTFS WinRE
Is there any way I can add my Windows bootloader to GRUB?
I think I might have found the issue but reading the other post and trying the answers did not help. /dev/sda3/ and /dev/sdc2/ are marked as boot as far as I understood. /dev/sdc2 is my Windows home drive, while /dev/sdc1 is the actual boot loader and for Linux /dev/sda3 is the root folder and /dev/sda2 the supposed to be boot loader.
The first answer of the linked post
I have made it work somewhat, but when restarting after having added the custom.cfg to the /boot/grub/ I get the following Error:
no such device:/EFI/Microsoft/Boot/bootmgfw.efi
