after installing Ubuntu 16.04, when I choose in grub startup menu to boot in Windows 10 it restart PC but loop again in grub start up menu. I tried - boot repair (to correct it - "recomended change") - sudo update-grub also. So as I wrote after installing Ubuntu 16.04, when I select Win10 in grub, it restart computer, but again shows grub bootup menu... Basic information - older desktop (no UEFI), - 1. installed Win Xp, 2. Windows 10, both load without problem, - Win10 shut down, but fast boot was not disabled (in ubuntu I can see other drives, but ubuntu cannot mount them) - 3. installed Ubuntu 16.04
As first on HDD I had 2 NTFS partitions (50 and 70GB), on the first was Win XP, I split it ( 50GB to 20GB Win XP and new 30GB) and on new part I install win 10. After this I split the second partition (70GB in 30GB and 40GB) and on the 30GB I install Ubuntu 16.04 (the partition during installation was split into 20GB - system and rest /shows 8,6GB/ as "HOME"), after few restart I try to choose Win 10 during booting, but as I wrote earlier, I cannot access Windows.
When you can help me, thank you for your answer/help
PS.: When I correct installation (using Win 10 installation disk) - fix MBR, I can run Win10 (including Win XP) - but of course not Ubuntu. So then I again reinstall Ubuntu 16.04, but problem occurs again, and I cannot access my Window installations...!
Zivi
This is what you need: Boot Repair
Refer to the instructions given on the site and your windows boot entry will be added to the grub menu.
