So I have a little systemd-script which is supposed to hibernate my laptop after it has been in suspend mode after x amount of seconds (filename is /lib/systemd/system-sleep/0000rtchibernate.sh):
#!/bin/bash
# Script name: /usr/lib/systemd/system-sleep/0000rtchibernate.sh
# Purpose: Auto hibernates after a period of sleep
# Edit the "autohibernate" variable below to set the number of seconds to sleep.
curtime=$(date +%s)
autohibernate=10 #for testing purposes
sleeptime=2
logging=true
logfile="/lib/systemd/system-sleep/0000rtchibernate.log"
skipfile="/lib/systemd/system-sleep/0000rtchibernate.skip"
lockfile="/tmp/rtchibernate.lock"
echo "$curtime $1" >>/tmp/autohibernate.log
if [ "$2" = "hibernate" ]; then
if [ "$logging" = true ]; then
echo "$(date) : Hibernating, doing nothing" >> $logfile
fi
exit 0
fi
if [ "$1" = "pre" ]; then
# only set timer if file 0000rtchibernate.skip doesn't exist
if [ ! -f $skipfile ]; then
# Suspending. Record current time, and set a wake up timer.
echo "$(date) : Suspending" >> $logfile
fi
echo "$curtime" > $lockfile
rtcwake -m no -s $autohibernate
fi
fi
if [ "$1" = "post" ]; then
if [ -f $skipfile ]; then
# if skipfile is present on resume, remove it
echo "$(date) : Removing skipfile" >> $logfile
fi
rm $skipfile
else
# Coming out of sleep
sustime=$(cat $lockfile)
rm $lockfile
# Did we wake up due to the rtc timer above?
if [ $(($curtime - $sustime)) -ge $((autohibernate-5)) ]; then
echo "$(date) : Hibernating" >> $logfile
fi
# Then hibernate
/bin/systemctl hibernate
return_val=$?
echo "$(date) : Return value of systemctl hibernate was $return_val" >> $logfile
fi
# if hibernation fails, create skipfile and suspend
if [ "$return_val" -gt 0 ]; then
echo "$(date) : Hibernation failed. Creating skipfile and suspending" >> $logfile
fi
touch $skipfile
/bin/systemctl suspend
fi
else
echo "$(date) : Waking up early, not hibernating" >> $logfile
fi
# Otherwise cancel the rtc timer and wake up normally.
rtcwake -m no -s 1
fi
fi
fi
(code is originally from here, I only adapted it to systemd)
The scripts runs fine when suspending the laptop, here is the logging output:
Di 20. Mär 10:53:31 CET 2018 : Suspending
Di 20. Mär 10:53:44 CET 2018 : Hibernating
Di 20. Mär 10:53:44 CET 2018 : Return value of systemctl hibernate was 1
Di 20. Mär 10:53:44 CET 2018 : Hibernation failed. Creating skipfile and suspending
My problem is that both /bin/systemctl hibernate and /bin/systemctl suspend have a return value of 1 and don't do what they're supposed to, although when running from a terminal window everything is fine. Btw I'm on Ubuntu 18.04. Any help appreciated :-)
