I have a lot of files to process and I need to replace their original names with this format in bash:
and so on
and so on
Adapted from one of Oli's answers:
rename -n 's/.+/our $i; $i++; sprintf("%014d_1.jpg", $i)/e' *
This takes every file in the current directory and renames it with a number with 14 digits (I hope I counted correctly) followed by _1.jpg. our $i introduces a global variable i, which is then increased by one and printed with sprintf. e commands rename to evaluate the right side of the replacement (= everything between the second and the third /) as an expression rather than literally. If you're happy with the results, remove -n to perform the renaming.
If you want to dive into perl expressions and their beauty, the perldoc is the way to go.
Would this works for you :
i=1
for file in *; do
mv "$file" "$(printf %014d $i)_1.jpg"
i=$((i+1))
done
It will rename every file in the current directory like this :
