-1
I am trying to install git on Ubuntu 16.04 LTS but every time I get this message. I have already uninstalled libpcre2-8-0, and synaptic shows nothing in broken packages. It shows only when I mark git-core package to install, and I don't know what to do after.
$ sudo apt install git
Reading package lists... Done
Building dependency tree
 git : Depends: libpcre2-8-0 (>= 10.22) but 10.21-1 is to be installed
wjandrea
  • 14,504
Vehns
Simple solution use synaptic.
What you could try
sudo apt install libpcre2-8-0
Otherwise get synaptic if possible and try to install git through it. It's a front end application for apt. Try to install it with apt. If issues occur, get the packages from here https://packages.ubuntu.com/xenial/
dpkg -i ~/Downloads/'package name'
This will also give you the output if you need anything else.
