The store says WINE is installed, but I don't see it in my apps, or an option to use WINE to open a .exe file.
You can find installed WINE and WINE-related packages with the following command:
dpkg -l | grep ^ii | grep -i wine
You can find its default prefix with its size by
ls -ld ~/.wine
du -sh ~/.wine/*
and other prefixes (usually created by winetricks) with
ls -ld ~/.local/share/wineprefixes/*
du -sh ~/.local/share/wineprefixes/*
- 103,263
To rightfully see if WINE is installed you should run:
which wine
The which command will either return an exit status of 0 if installed or a 1 if not installed...
To find the exit status of the command, simply run:
echo $?
It is a very simple yet important command to know about...
- 2,608
You can use the -s (status) switch of dpkg:
dpkg -s wine
Returns 0 if installed or 1 if the program is not installed.
Another way to see if a package is installed and which version (Installed: [...]). You also see which version would be installed (Candidate: [...]).
apt-cache policy <package name>
apt-cache policy wine
Advantage of apt-cache: You can use wildcards(*) if you don't know the exact package name.
- 27,991
