I was looking for a way to get gnome style notifications in Unity. Or at least, if there´s a way of making the default Unity notifications interactive and clickable? As it is by default only a notification pops up and the user needs to find the relevant window, which I find very counterproductive.
You can have clickable notification with Unity.
Tested with 12.10, 13.04, 13.10, 14.04, 14.10, 16.04 (thanks @ManseUK).
What we want
Notification are supposed to non-obstrusive, non-disrupting of your train of thought, and provide a shortcut when relevant.
Problem in Unity (12.04, 12.10 at least)
Default notification engine is notify-osd.
- notifications are not clickable (which hurts efficiency for those that offer to quickly bring you to the place of interest).
- when several happen quickly, they queue and appear only one after the other : no way to see them quickly, you just have to ... wait.
Solution
Current XFCE notifications on the other hand implement just that, and they can be used with Unity. I just tested it with a separate account (default config) to rule out any user-specific settings.
Howto
Here's how install and use XFCE4's notifications instead of Unity's:
sudo apt-get install xfce4-notifyd ; sudo apt-get purge notify-osd
To get immediate effect this may help (else logout/login):
killall -v notify-osd
/usr/lib/*/xfce4/notifyd/xfce4-notifyd &
You might want to test and adjust appearance:
xfce4-notifyd-config
- 2,089
Sorry, this is not possible.
Ubuntu's notification system, NotifyOSD, as used by Unity, is designed to be un-clickable, in order to simplify the experience and not confuse users. There is no way to change that.
Gnome Shell, on the other hand, uses another built-in notification system that behaves differently to NotifyOSD, as explained in this LXNews article
- 8,707
- 254
Tested on Ubuntu Unity 18.04
You do not need to purge or remove notify-osd to switch to xfce4-notifyd. You can simply change the default notification utility.
Before you begin, install xfce4-notifyd by running the following commands:
sudo apt update
sudo apt install xfce4-notifyd
Next, run the following command to edit your default, dbus notification-service configuration file:
sudo nano /usr/share/dbus-1/services/org.freedesktop.Notifications.service
Then, edit the file to look like this:
[D-BUS Service]
Name=org.freedesktop.Notifications
# Exec=/usr/lib/x86_64-linux-gnu/notify-osd
Exec=/usr/lib/x86_64-linux-gnu/xfce4/notifyd/xfce4-notifyd
SystemdService=xfce4-notifyd.service
If you notice, the 3rd line is commented out and the last two lines are added to the original file.
When you are done editing, press CTRL+o to save the file and then press CTRL+x to exit nano.
Finally, reboot to apply the changes.
- 44,904
- 8
- 102
- 162
