I have an MSI GE72 laptop and the touchpad simply does not work. My output of less /proc/bus/input/devices is :
I: Bus=0011 Vendor=0001 Product=0001 Version=ab41
N: Name="AT Translated Set 2 keyboard"
P: Phys=isa0060/serio0/input0
S: Sysfs=/devices/platform/i8042/serio0/input/input0
U: Uniq=
H: Handlers=sysrq kbd event0 leds
B: PROP=0
B: EV=120013
B: KEY=600702900000 8380207af040d001 feffffdfffefffff fffffffffffffffe
B: MSC=10
B: LED=7
I: Bus=0003 Vendor=0461 Product=4e22 Version=0111
N: Name="PixArt USB Optical Mouse"
P: Phys=usb-0000:00:14.0-8/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:0461:4E22.0002/i
nput/input1
U: Uniq=
H: Handlers=mouse0 event1
B: PROP=0
B: EV=17
B: KEY=ff0000 0 0 0 0
B: REL=103
B: MSC=10
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="HDA Intel PCH Mic"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input2
U: Uniq=
H: Handlers=event2
B: PROP=0
B: EV=21
B: SW=10
N: Name="HDA Intel PCH Headphone"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input3
U: Uniq=
H: Handlers=event3
B: PROP=0
B: EV=21
B: SW=4
N: Name="HDA Intel PCH HDMI/DP,pcm=3"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input4
U: Uniq=
H: Handlers=event4
B: PROP=0
B: EV=21
B: SW=140
N: Name="HDA Intel PCH HDMI/DP,pcm=8"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input6
U: Uniq=
H: Handlers=event6
B: PROP=0
B: EV=21
B: SW=140
and my output from xinput is :
⎡ Virtual core pointer                      id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ PixArt USB Optical Mouse                  id=6    [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=7    [slave  keyboard (3)]
I do have an optical mouse plugged in so I can use the GUI but cannot get Ubuntu to recognize my touchpad at all. I have installed xserver-xorg-input-synaptics already as well as xserver-xorg-input-synaptics-dev and neither made my touchpad get recognized. I am rather new to linux so any troubleshooting suggestions would be much appreciated.
Ok, I founded the problem. Is necessary to put "acpi=on" on the grub, in order to activate the irq controller properly.
Thanks.
This link helped me to fix the issue Booting Ubuntu with "acpi=off" grub parameter
$ cd /etc/default
$ sudo vi grub
Use the vi editor to add the boot options to the line
GRUB_CMDLINE_LINUX_DEFAULT=
and make it (in my case):
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash pci=noacpi”
Finish with:
$ sudo update-grub
$ sudo reboot
