Is there a way to prevent files to be overwritten, if the file with the same name already exists?
Either it should ask for root password to confirm or simply save it with a new name, like windows does, adding numbers to names.
- 367
- 3
- 16
The best method would be for you to learn to create a copy yourself before editing a file.
That said ...
Yes. From command line set the "immutable" attribute (only the admin can remove that option) and nobody will be able to alter the file (edit, remove, move etc.). You do that with ...
sudo -i
{password}
chattr +i {file}
(-i to remove it)
Ubuntu does not have a use able root password.
You can modify a file (even if it's read-only) if you own it and have write access to the directory. See for instance Why can I modify a read-only file? on how to save from vim. It will then complain that you need to take an extra action before you can save it.
Not exactly what you asked but it is a method to get some sort of notification before you overwrite it.
You will need a script for that when doing that on command line. Here are some examples: https://stackoverflow.com/questions/12187859/create-new-file-but-add-number-if-filename-already-exists-in-bash
- 309,379
