I replaced windows 10 with ubuntu 16.04 (from a live USB) on a new laptop right away. but both ethernet and wifi were not working (the entire "enable wifi" option was not there, and of course, no wifi networks were displayed). After a day of research and finding no solutions, i did a clean install but the problem persisted, then i did a clean install of ubuntu 17.10, and again, the problem remained for wifi, at which point i continued attempting to find a solution for another day and half to no avail. (however, i did just try ethernet again, it's now working. I fear that it may have been working all along and the wire i tested with the first time was not working. I'm about to clean install Ubuntu 16.04 again to figure out whether ethernet was actually not working there or if i was using a bad wire)
The following is the result of running "sudo lshw -C network"
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eno1
version: 15
serial: ac:e2:d3:d2:31:da
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:127 ioport:4000(size=256) memory:a2104000-a2104fff memory:a2100000-a1203fff
*-network UNCLAIMED
description: Network controller
product: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: ioport:3000(size=256) memory:a2000000-a200ffff
and the following is the relevant part of the "lsusb" command result:
Bus 001 Device 003: ID 0bda:b009 Realtek Semiconductor Corp.
and the "lspci" command result (relevant part):
02:00.0 Ethernet controller: Realtek Semiconductor CO., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: Realtek Semiconductor CO., Ltd. Device d723
note that all the results above have been exactly the same whether i was using ubuntu 16.04 or 17.10.
While i found many similar problems while researching, this solved question answered by the user chili555 seems to be the exact same question as mine but with a different device, adapter, drivers and firmwares. I think that the same solution he gave there should work for me if the driver's and firmware's names were adjusted to fit my case. but I haven't been able to find out how to identify which drivers are incorrectly installed in my case, and which drivers and firmwares i should load and install. also, now that I found out that ethernet is indeed working for me, I'm not sure if the problem in that question is the same as mine or not.
I'll update question when I test ethernet on ubuntu 16.04 again
update: now running ubuntu 16.04. ethernet is indeed working.
As for the duplicate claim. my question differs from this question which was marked as a duplicate of this question in that they are both simply asking for the drivers (and quite generally, without providing details about their hardware or the problems they're having). In the last part of my question, i did talk specifically about the drivers and firmware because that's what my research yielded as the most probable solution. ie, even if the solution to my network UNCLAIMED problem is installing and loading the drivers that were asked for in these two questions, my question is still different as I'm asking about a specific problem (network UNCLAIMED).
I installed the driver (https://github.com/jeremyb31/rtl8723de.git) and built it successfully, then ran sudo reboot, but the problem persists. network still unclaimed, "enable wifi" still not showing and no wifi networks are displayed. and I'm certain it was built successfully because when i attempted to do it again, the result was "module already built for "
