I want to install MyPaint and followed this answer.
sudo add-apt-repository ppa:achadwick/mypaint-testing
sudo apt-get update
sudo apt-get install mypaint mypaint-data-hires
But it gives this error
Reading package lists... Done
Building dependency tree
Package mypaint-data-hires is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  mypaint-data-extras
E: Package 'mypaint-data-hires' has no installation candidate
I also tried to install it from ubuntu software centre where it gives unauthenticated error. even accepting this error nothing installs.
Terminal installation
sudo apt-get install mypaint mypaint-data-extras
gives this error
The following NEW packages will be installed:
  mypaint mypaint-data mypaint-data-extras
0 upgraded, 3 newly installed, 0 to remove and 2 not upgraded.
Need to get 27.9 MB of archives.
After this operation, 38.4 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
WARNING: The following packages cannot be authenticated!
  mypaint-data mypaint mypaint-data-extras
Install these packages without verification? [y/N] n
I denied installation because its unverified. Should I install it?
If this app cant be installed can you suggest some light weight paint apps?
EDIT
Result for sudo apt-key update
gpg: keyblock resource `/etc/apt/trusted.gpg.d/webupd8team-y-ppa-manager.gpg': resource limit
gpg: keyblock resource `/etc/apt/trusted.gpg.d/yannubuntu-boot-repair.gpg': resource limit
gpg: key 437D05B5: "Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.com>" not changed
gpg: key FBB75451: "Ubuntu CD Image Automatic Signing Key <cdimage@ubuntu.com>" not changed
gpg: key C0B21F32: "Ubuntu Archive Automatic Signing Key (2012) <ftpmaster@ubuntu.com>" not changed
gpg: key EFE21092: "Ubuntu CD Image Automatic Signing Key (2012) <cdimage@ubuntu.com>" not changed
gpg: Total number processed: 4
gpg:              unchanged: 4
Eka
  • 3,007
I have solved the problem. It was not a problem of MyPaint but something to do with GPG and PPA. I have followed this answer.
I first did sudo apt-get update and recieved error simialr to this enter image description here
and then went to software and updates > Other softwares and unchecked all error causing PPAs
Then when I updated sudo apt-get update it showed additional error in GPG error...NO_PUBKEY This is solved by
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys <PUBKEY>
Eka
  • 3,007
