I have a slightly unusual setup which I am failing to get running:
-Dell Precision Laptop with two identical NVME SSDs -I'd like to install Ubuntu to them with RAID 0 and full disk encryption -The Device uses UEFI booting, Secure Boot is turned off
The Ubuntu Desktop installer requires me to set up the RAID before the installer, then I can select automatic partitioning with encryption on the combined RAID partition, but then it fails to install GRUB. I also tried the server installer, it allows me to set up RAID and the encryption, but still doesn't install GRUB. I have read that I need to manually create a 200MB FAT32 partition for the boot loader but that also didn't work.
How exactly should my partitioning layout look like? Should the FAT32 partition be on both drives? Should they also be in RAID? Or is there some way I should manually install the boot loader afterwards and add the entries to the UEFI?
