I love bitmap fonts in my xterm, they look very good, there is no subpixel rendering or other antialiasing, but the fact they are hand made in regards to every pixel makes it cool. But I do not know how to find such fonts on the Internet and how to install them in my Ubuntu and then select them with xterm.
What I need is a detailed instruction for all three steps:
  • finding/downloading
  • installing into x11
  • make use by xterm
Here is how I set up fixed-medium now, but I have no much idea what it means, and how to select a particular file:
xterm -ls -font '-*-fixed-medium-*-*-*-18-*-*-*-*-*-*-9'  -b 20
This is what I used before, for TrueType fonts, which I do not want to use anymore for my xterm:
xterm -fs 11 -fa AndroidMono -geometry 120x30 -n 'terminal' -ls
galoget
  • 3,023
exebook
  • 389
You have 80+ standard packages with "xfont" in their name. Some of these are bundles for specific purposes like "web", "biz", etc. so hundreds of x fonts available to install.
Setting up default fonts in an xterm is well covered in How to Change the Default font size of XTerm
One additional method of selection not covered in the above link using an escape sequence to change the font in an xterm. First, ensure that "Allow Font Ops" is checked in the ctrl-R mouse button menu (near the bottom). The echo command:
echo -n -e "\033]50;8x16\007"
sets the font to 8x16. Put the command into a script you can run, passing the font as an argument:
#/bin/bash
# mychfnt script
MYFNT=${1-8x16}
echo -n -e "\033]50;$MYFNT\007"
e.g. put an executable file named chfnt with the above into your $HOME/bin directory, and whenever you want to change fonts, use
xlsfonts
to list the available fonts, and then select one and
chfnt "-sony-fixed-medium-r-normal--24-230-75-75-c-120-iso8859-1"
ubfan1
  • 19,049
