I can't properly enter the ubuntu 16.04 LTS anymore. The boot stops with this message:
/dev/sda5: clean, xxxxx/xxxxx files, xxxx/xxxxx blocks.
I've had the pc running normal for 3 years now, and 2 days ago there were a power outtage, which shutdown the pc. When the power was back on and I turned on the pc, fsck started and stopped at this line. The only possible actions that I can take is:
mannualy reboot - which will take me back to this message once the computer boots again.
ctrl + alt + F1 - which allows me to actually work with the computer in a line of command. However, with this option I can't run any kind of application that requires a GUI (gparted or gthumb, for example). But I see that all my files are preserved.
I did see a few answers to this problem, saying that the message xx/xx files xx/xx blocks is normal and it means that everything is fine, but I cannot get past this message unless I run ctrl + alt + F1, so there is clearly something wrong.
A few things that I tried:
login (via ctrl+alt+F1) and run fsck -f: returns a warning message saying that it may damage the computer.
Enter the pc via recovery mode and run the fsck for all filesystems: It stops the verification once it reaches "Reached target Swap." After this, I can only hit enter and go the recovery mode menu.
Enter the pc via recovery mode > root > hit enter (for maintenance) > run sudo fsck -f /dev/sda5
The results are:
Pass 1: Checking inodes, blocks and sizes;
Pass 2: Checking directory structure;
Pass 3: Checking directoru connectivity;
Pass 4: Checking reference counts;
Pass 5: Checking summary information;
/dev/sda5 xxx/xxx files (0.2% non-contiguous), xx/xx blocks
Which, at this time, to me it means that the problem is still there.
I don't know what to do. Can anyone help me?
Thanks
Edit for the blkid and cat commands, as requested.
sudo blkid:
/dev/sda1: SEC_TYPE="ms-dos" LABEL="Dell Utility" UUID "5450-4444" TYPE="vfat" PARTUID="2ac21a9f-01"
/dev/sda2: LABEL="RECOVERY" UUID="964A9B734A9B4F3D" TYPE="ntfs" PARTUUID="2ac21a9f-02"
/dev/sda3: LABEL="OS" UUID="085C9DD05C9DB8C0" TYPE="ntfs" PARTUUID="2ac21a9f-03"
/dev/sda5: UUID="541386d5-b86c-41ad-bd00-d8af887358a9" TYPE="ext4" PARTUUID="2ac21a9f-05"
/dev/sda6: UUID="806ceccd-9af2-48d1-8995-4ca5e48342ba" TYPE="swap" PARTUUID="2ac21a9f-06"
cat /etc/fstab output (ignoring the first paragraph):
< file system > < mount point > < type > < options > < dump > < pass > (this line is commented)
 / was on /dev/sda5 during installation (this line is commented)
UUID=541386d5-b86c-41ad-bd00-d8af887358a9 / ext4 errors=remount -ro 0 1
 swap was on /dev/sda6 during installation (this line is commented)
UUID=806ceccd-9af2-48d1-8995-4ca5e48342ba none swap sw 0 0
Félicien
  • 1,203
André
  • 31
Because of the "Reached target Swap" error, the problem may be related to your swap partition on your hard disk. (You shouldn't be running fsck on sda6... if you are, then that is why you're getting this error, and you can ignore the rest of this answer.)
I've reviewed your sudo blkid and cat /etc/fstab output, and they look OK... the UUID's from sda5 and sda6 match correctly.
Lets try to temporarily disable swap, and see if the machine boots fully. At the root command prompt, type:
sudo pico /etc/fstab
change this line:
to this:
#UUID=806ceccd-9af2-48d1-8995-4ca5e48342ba none swap sw 0 0
control-o # to save the edit
control-x # to exit the editor
reboot
And see if the machine will fully boot. Report back.
Note: if the machine does NOT boot fully, you'll need to reverse this edit.
Update #1:
Lets temporarily enable console logging so we can see where it stops booting. You'll reverse this process later.
At the root command prompt:
sudo pico /etc/default/grub
Find the line, near the top, that contains the words quiet splash and remove those two words. Remember where you do this, so that you can replace them later.
control-o # save the edits
control-x # exit the editor
sudo update-grub # update grub
reboot # reboot the computer
Watch where the boot stops, for errors, or for the last few lines of text, to help determine where the problem is.
heynnema
  • 73,649
