I am using Ubuntu 16.04.3 LTS. While installing Firefox, this error is shown:
The following NEW packages will be installed:
Reading package lists... Done
Building dependency tree
  firefox
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 44.5 MB of archives.
After this operation, 176 MB of additional disk space will be used.
Get:1 http://security.ubuntu.com/ubuntu xenial-security/main amd64 firefox amd64 58.0.2+build1-0ubuntu0.16.04.1 [44.5 MB]
Err:1 http://archive.ubuntu.com/ubuntu xenial-updates/main amd64 firefox amd64 58.0.2+build1-0ubuntu0.16.04.1
  Hash Sum mismatch
Get:1 http://archive.ubuntu.com/ubuntu xenial-updates/main amd64 firefox amd64 58.0.2+build1-0ubuntu0.16.04.1 [44.5 MB]
  Hash Sum mismatch
Fetched 88.9 MB in 2min 23s (621 kB/s)
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/f/firefox/firefox_58.0.2+build1-0ubuntu0.16.04.1_amd64.deb  Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
How can I fix "Hash Sum mismatch"?
linix
Try removing all the content of /var/lib/apt/lists directory, you can use this command:
sudo rm -rf /var/lib/apt/lists/*
Then execute this command:
sudo apt update
And finally, try to install firefox again:
sudo apt install firefox
If this doesn't work, you can try:
Settings → Software & Updates → Ubuntu Software: Download from: Change Local to Main Server, or any other Server that is close to you.
Hope it helps.
galoget
  • 3,023
