I tried to install pgAdmin III for my ubuntu 17.10 without successful either via command line or software center:
sudo apt-get install pgadmin3
Resulted in
Reading package lists... Done
Building dependency tree
pgadmin3 : Depends: pgadmin3-data (= 1.22.2-1) but 1.22.2-2.pgdg17.04+1 is to be installed
Installing from software center, I got an error as screenshot below:
How do I check what is wrong and get pgAdmin III installed successfully? Thanks.
