I want to know how to share any folders between android and ubuntu. I've got it with WindowsXP. On my Android phone I've installed the app ES File Explorer. I've created a folder in the PC and it is shared. With the app from cellphone I can find the shared folder but when I try open it, the app says 'The account has no permissions' I don't know how to give these permissions.
coversnail
  • 6,406
Javi
  • 51
8 Answers8
Ohk.. I was trying the same thing, below is what worked:
In nautilus, right click on the folder you want to share and select 'sharing options', where you enable sharing the folder. In the same window, there are 2 other options: 'Allow others to create and delete files in this folder' and 'Guest Access'. Check both the options.. Exit Nautilus (on computer) and ES file explorer (on android phone). Reopen ES file explorer and connect to the shared folder again... That should fix the issue...
Dowload and install the android app Airdroid from Playstore..
It will share files between the Ubuntu pc and your android phone via wifi.
Avinash Raj
  • 80,446
I am not sure if it is the correct solution to your problem..
You can use Airdroid app on android market. It lets you access all you android folder in a browser.
abhishek
  • 2,696
  • In Nautilus, right-click on the folder that you want to share.
  • Then select Local Network Share
  • Check 'Allow others to create and delete files in this folder'
  • Check 'Guest access'
  • Apply
  • Make sure both the computer and your android device is connected to the same network (wifi)
Most file manager apps in Android have the feature to search and connect to network drives (SMB) in the local network.
In new Samsung devices, you could use the 'Network Storage' feature provided in the default 'Files' app:
https://r2.community.samsung.com/t5/Tech-Talk/new-feature-Network-storage/td-p/4147865
Or use an app like ES File Explorer to connect to the shared storage.
Gayan Weerakutti
  • 3,830
  • 28
  • 39
If you just want to share media files, then rygel might be what you need. It's in the repositories. Type this command in a terminal to install it:
sudo apt-get install rygel rygel-preferences
Rygel is an uPnP DNLA service.
Eliah Kagan
  • 119,640
"send anywhere" works with folders. it provide deb package and works well in ubuntu.
eexpress
  • 269
You could give permission to a folder in two ways: (do them in ubuntu)
-1
I save files on my Ubuntu machine. Then I connect to it using sftp from within the ES File Explorer application for Android. I made a bookmark to the Ubuntu directory on my Android desktop and can access it very conveniently.
Selah
  • 2,995
