Okay, i wanted to ask this on amd support directly but i cant create an account there because there suppoort forum does not work (omfg, sometimes i really ask myself if EVERYTHING is fu**** BROKEN these days)
Okay, lets explain my problem: At work i assembled a new pc featuring a amd graphics card (RX 550) and 2 Iiyama WQHD Screens (2560x1440). Everything worked fine using the default configuration. One Screen is attached via DisplayPort and the other via DVI.
Now i wanted to dig a little into WebGL and 3D and figured it might be good to install the latest gpu drivers directly from the vendor. So i installed the amdgpu-pro driver like explained on the amd website.
After rebooting the DVI attached screen is configured to 1920x1200 and i dont have an option to set it back to 2560x1440.
Whats so extraordinary in my setup?
I dont get it, whats so exotic in connecting 2 Screens to a new graphics card? Using the current Long-Term-Support Release of one of the biggest linux distributions in the world? Why cant this sh** just work?
I had similar problems with a notebook i used some months ago. That notebook had a Nvidia Gforce GTX1030 or something like that built in.
How could i solve this without wasting massive time in learning about Xorg (what i really dont want to, i dont care so much about lowlevel stuff, just want this machine to do like its supposed to)
lshw -C display output
Beschreibung: VGA compatible controller
Produkt: Advanced Micro Devices, Inc. [AMD/ATI]
Hersteller: Advanced Micro Devices, Inc. [AMD/ATI]
Physische ID: 0
Bus-Informationen: pci@0000:23:00.0
Version: c7
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: pm pciexpress msi vga_controller bus_master cap_list rom
Konfiguration: driver=amdgpu latency=0
Ressourcen: irq:305 memory:e0000000-efffffff memory:f0000000-f01fffff ioport:e000(Größe=256) memory:fe800000-fe83ffff memory:c0000-dffff
What confuses me here is the "VGA Compatible Controller", I installed the correct driver like explained, my video card is listed here
When running grep -i chipset /var/log/Xorg.0.log
i get
[ 157.137] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
[ 157.139] (II) VESA: driver for VESA chipsets: vesa
[ 157.141] (--) AMDGPU(0): Chipset: "Radeon RX 550 Series" (ChipID = 0x699f)
Why does linux have to be so much pain all the time :-(
When i executed the following script i got it working the notebook featuring the nvidia graphics.
#!/usr/bin/env bash
sudo xrandr --newmode "2560x1440_56" 225.000 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync
sudo xrandr --addmode HDMI-1-2 "2560x1440_56"
sudo xrandr --output HDMI-1-2 --mode "2560x1440_56"
exit
But hey - i dont really know what i am doing there so i would prefer a real fix for my problem.
And one final Off-topic Question: Is there ONE Distribution/GPU Combination that works - that you could recommend? I learned, that AMD is absolutely horrible I learned, that Nvidia is even worse!!
Is there only intel IGPU left?
