Possible Duplicate:
How to start applications at startup automatically in Unity?
How to edit autostart applications?
I want Terminal to start up right when i login. Is there a command? If so, I'm using Bash.
jaorizabal
  • 3,778
Open the Dash (press Super key, or "Windows" key) and type:
 Startup Applications
Open the resulted application.
Now open up the Dash again and this time type:
terminal
Now drag&drop the resulted application to the earlier opened Startup Applications.
Now if you want you can test this by logout and log in again.
COnsider creating custom scripts and add them as comands in your Startup Applications
bioShark
  • 4,315
For Gnome :
System ->Preferences ->Startup Applications (select your application there)
For Unity:
press Alt + F2 and select the application you want to appear on startup
dlin
  • 3,900
