I made an application with Mono, and I want it is always running. If my application stopped, I need it to automatically start again. Does anyone have solution that would help me?
Also, how do I start an application at startup?
I would go for the following approach:
Make a shell script to start the app again if it is stopped (make sure that it is marked as executable):
#!/bin/bash
while true ; do
mono /path/to/exe
done
The loop is paused each time the mono command is run, as it will wait for it to complete, so your app shouldn't launch hundreds of times.
Then, you can make it launch at logon.
Log out, then log back in again, and hopefully your mono application should be running.
