I have downloaded ubuntu-16.04.4-desktop-amd64.iso (which is a winRAR archive file)on Windows VISTA. Can I install Ubuntu along with Vista and if yes, how to install it from this winRAR file?
Asked
Active
Viewed 857 times
Dual booting is simple. Just perform the steps as given below:
- Extract the WinRAR archive to obtain your
.isofile - Download Universal USB Installer software via
Googleand use it to create a bootable USB - Once you have a bootable USB handy, click on
Windowsicon and search fordisk management. Select the optionCreate and format hard disk partitions - To install Ubuntu, take help of dual boot Ubuntu and Windows and ensure you perform the steps as given in that link
Once you have installed Ubuntu (as per the steps given in the link), simply reboot your system and choose which OS you would like to boot into
In case you are not presented with the option to choose OS on boot, then you need to setup your GRUB menu. To do so, proceed with the next set of steps:
Steps to install GRUB
Again boot into
WindowsOSCombine
Windows+rtogether and typecmdto open command promptType
bcdedit /set "{bootmgr}" path \EFI\ubuntu\grubx64.efiand hitEnterkeyReboot your system and then on every boot you will be presented with a proper GRUB menu to choose OS.
P.S - You do not need to have admin rights on command prompt before you perform the above action.
Manu Mathur
- 1,048
