I'm trying to install Maya 2017 on Ubuntu 16.04 LTS.
So far, everything looks good until it comes to the alien command to get .deb out of the .rpm.
root@Borderline-Central:~/maya2017Install# alien -c *.rpm
sh: 1: rpm: not found
Error executing "LANG=C rpm -qp --queryformat %{NAME}'adlmapps12-12.0.32-0.x86_64.rpm'":  at /usr/share/perl5/Alien/Package.pm line 489.
root@Borderline-Central:~# apt install rpm
Reading package lists... Done
Building dependency tree
rpm is already the newest version (4.12.0.1+dfsg1-3build3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@Borderline-Central:~# rpm
The program 'rpm' is currently not installed. You can install it by typing:
apt install rpm
If I try
for i in *.rpm; do sudo alien -cv $i; done
Same problem with rpm not found.
I've tried to purge rpm, installed it again. It doesn't help at all
I've started with Ubuntu a month ago so I'm new and I think I'm missing something.
rpm is installed but can't be found somehow.
What's the problem and how can I fix it?
It's not a duplicate question, I've done the installation similar to the description in the link to GitHub. But my problem is that rpm isn't found even if it's said rpm is already the newest version. So still the question. How can I fix the missing rpm problem!?
As requested the output of which rpm and ls -l /usr/bin/rpm
hethu@Borderline-Central:~$ which rpm
/usr/bin/rpm
hethu@Borderline-Central:~$ ls -l /usr/bin/rpm
-rwxr-xr-x 1 root root 15208 Jan 19  2016 /usr/bin/rpm
Hethu
