I'm trying to access Windows files from Ubuntu. I mounted the Windows partition in read-only to /media/windows, but when I open the folder, it's empty. The Windows partition is displayed as 723 GB volume, but the properties window shows it has 67 GB of free space.
The command I used to mount was mount -t ntfs-3g -o ro /dev/sda4 /media/windows.
Output of sudo blkid:
/dev/sda1: LABEL="Windows RE tools" UUID="0CCEE142CEE12524" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="3072e097-bb5b-41d5-b5ee-e801527cb141"
/dev/sda2: LABEL="SYSTEM" UUID="20E3-F007" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="47deba7d-da92-401a-9fb7-d7bb01ac2425"
/dev/sda5: UUID="2C1CF5D91CF59DD0" TYPE="ntfs" PARTUUID="820d4aff-a44b-4341-aa3b-4be46fed9c00"
/dev/sda6: LABEL="SAMSUNG_REC2" UUID="7C801A62801A2366" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="b7453122-2976-4042-998e-c82abc9e79a9"
/dev/sda7: LABEL="SAMSUNG_REC" UUID="FCE9-01ED" TYPE="vfat" PARTLABEL="Basic data partition" PARTUUID="93c03d23-427a-4089-4173-636c65706975"
/dev/sdb1: LABEL="UBUNTU 16_0" UUID="145A-3702" TYPE="vfat" PARTUUID="42637dc3-01"
/dev/loop0: TYPE="squashfs"
/dev/sda3: PARTLABEL="Microsoft reserved partition" PARTUUID="4e780686-2d33-43ea-968e-ce75355669bd"
My laptop model and make is a Samsung 300e, if that helps.
From sudo fdisk -l |grep sd:
Disk /dev/sda: 698.7 GiB, 750156374016 bytes, 1465149168 sectors
/dev/sda1        2048    1026047    1024000   500M Windows recovery environment
/dev/sda2     1026048    1640447     614400   300M EFI System
/dev/sda3     1640448    1902591     262144   128M Microsoft reserved
/dev/sda4     1902592 1413550080 1411647489 673.1G Microsoft basic data
/dev/sda5  1413552128 1414471679     919552   449M Windows recovery environment
/dev/sda6  1414471681 1463050240   48578560  23.2G Windows recovery environment
/dev/sda7  1463050241 1465147392    2097152     1G Windows recovery environment
Disk /dev/sdb: 14.5 GiB, 15510536192 bytes, 30294016 sectors
/dev/sdb1  *     2048 30294015 30291968 14.5G  c W95 FAT32 (LBA)
Thomas Ward
  • 78,878
SentriCast
