I was tried running this command on Bash on Windows (WSL)
sudo apt-get install libudev1 libudev-dev libparted0-dev
because a program or a script requires these packages to run properly f3probe and f3fix by altMayor. I have tried to use apt-get update and with the fix missing commands and they didn't make a difference.
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/udev_229-4ubuntu21_amd64.deb  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libudev1_229-4ubuntu21_amd64.deb  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libudev-dev_229-4ubuntu21_amd64.deb  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/glibc/libc-dev-bin_2.23-0ubuntu9_amd64.deb  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/l/linux/linux-libc-dev_4.4.0-104.127_amd64.deb  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/glibc/libc6-dev_2.23-0ubuntu9_amd64.deb  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/util-linux/uuid-dev_2.27.1-6ubuntu3.3_amd64.deb  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/u/util-linux/libblkid-dev_2.27.1-6ubuntu3.3_amd64.deb  404  Not Found [IP: 91.189.88.149 80]
E: Aborting install.
Zanna
  • 72,312
Nonnick
A possible cause of 404 errors when trying to download packages via Apt is that the list of available packages on the system is out of date: Apt tries to download old versions of packages, which are no longer available, resulting in a 404. In such cases, the package list must be updated, for example with sudo apt update.
fkraiem
  • 12,813
