-1
I am trying to install postgreSQL
I open terminal and type the
gedit  /etc/apt/sources.list.d/pgdg.list
then in Gedit I enter this line
deb http://apt.postgresql.org/pub/repos/apt/ zesty-pgdg main
The when I try to save the file red colored text appears saying:
Could not save the file “/etc/apt/sources.list.d/pgdg.list”. you do not have the permission necessary to save the file. Please check that you typed the location correctly and try again
How do I solve this problem?
Zanna
  • 72,312
You need to modify this file as root. From the terminal, type
sudo -H gedit /etc/apt/sources.list.d/pgdg.list
Then you can modify inside gedit and save it as you tried before
The sudo command means that you will run the command as root and it will ask you for your password
Félicien
  • 1,203
