I'm working on both Ubuntu 17.10 and Windows 10 as a dual boot system. Suddenly today I restarted PC from Windows and tried to logged into Ubuntu and then I got stuck at emergency mode. Now I can't get pass the emergency mode. This is what I get and I'm stuck in this screen
[ 0.000000] [Firmware Bug]: TSC_DEADLINE disabled due to Errdata; please update
[ 1.982327] ACPI_Error: [\_SB_.PCIO.GFX0.DD02._BCL] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 1.982338] ACPI_Error: Method parse/execution failed \_SB.PCI0.RP05.PEGP.DD02._BCL, AE_NOT_FOUND (20170531/psparse-550)
[ 3.199674] [drm:intel_set_cpu_fifo_underrun_reporting [i915]] *ERROR* uncleared fifo underrun o
[ 3.199760] [drm:intel_cpu_fifo_underrun_irq_handler [i915]] *ERROR* CPU pipe a FIFO underrun
[ 3.455294] sd 4:0:0:0: [sdb] No Caching mode page found
[ 3.455351] sd 4:0:0:0: [sdb] Assuming drive cache: write through
/dev/sda10: clean, 473657/2869776 files, 5567557/1147616 blocks
You are in emergency mode. After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or D to boot into default mode.
Press Enter for maintenance
When I try to exit by pressing ctrl+D I it loads until 4.9% and redirected to this same screen. So I can't get pass trying to boot into default mode.
I checked and followed this askubuntu question by unmounting and running fsck -y for root directory with Ubuntu live cd. I don't think this is windows stutdown issue as I have been using the dual boot system for quite some time.
So, how can I get pass this and work on Ubuntu ? Any help would be appreciated.
