20
I'm trying to convert a PDF file (it's a book) into an image.
When I using convert like this
or like this
then I get this warning
Warning: Short look-up table in the Indexed color space was padded with 0's
for each page.
Is there some other tool I can use for conversion to get a bunch of images for this, or can someone show me a different way to solve this problem?
Octavian Helm
  • 14,515
One different way would be GhostScript:
gs -dNOPAUSE -dBATCH -sDEVICE=jpeg -r96 -sOutputFile='page-%00d.jpg' input.pdf
where -r96 is desired dpi resolution
Output are multiple JPEG images.
You can generate transparent PNGs also if you wish:
gs -dNOPAUSE -dBATCH -sDEVICE=pngalpha -r96 -sOutputFile='page-%00d.png' input.pdf
Seth
  • 59,332
zetah
  • 9,871
16
When converting to jpg, you can use the -quality option. The "best" quality would be -quality 100.
There is a much simpler way to split multipage pdfs into a jpg:
    The -density option defines the quality the pdf is rendered before the convert > here 600dpi. For high quality prints you can increase that number.
    The %d just before the jpg suffix is for automatic numbering of the output pages 0,1,2...
    The -quality option defines the compression quality of the output jpg (0 min ... 100 max)
    The .jpg suffix defines the output format. You could use .png/.jpg/.pdf
One Zero
  • 27,761
