Can't login into desktop environment after apt upgrade && reboot: on entering password the screen flickers into a black screen and returns back to the login screen. Login via the terminal (Ctrl+Alt+F1) works fine.
/var/log/Xorg.0.log says:
(EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
(EE) NVIDIA: system's kernel log for additional error messages and
(EE) NVIDIA: consult the NVIDIA README for details.
(EE) No devices detected.
$ dmesg says:
nvidia: version magic '4.4.0-116-generic SMP mod_unload modversions ' should be '4.4.0-116-generic SMP mod_unload modversions retpoline '
Trying to load the nvidia driver manually fails:
$ sudo modprobe nvidia
modprobe: ERROR: could not insert 'nvidia': Exec format error
Related: VirtualBox not starting after kernel upgrade
jfs
  • 4,078
The issue is with gcc version that doesn't support retpoline (What is a retpoline and how does it work?). See Ubuntu bug: 4.4.0-116 Kernel update on 2/21 breaks Nvidia drivers (on 14.04 and 16.04).
In my case, purging ppa:ubuntu-toolchain-r/test to install the default gcc version and rebuilding with DKMS the nvidia module (by reinstalling 4.4.0-116 kernel) fixes the problem. See instructions posted by @cjjefcoat on the bug tracker.
Restore default gcc by purging ppa:ubuntu-toolchain-r/test's version:
$ sudo apt-get install ppa-purge
$ sudo ppa-purge ppa:ubuntu-toolchain-r/test
gcc version (on Ubuntu 16.04) with retpoline support:
$ gcc --version
gcc (Ubuntu 5.4.0-6ubuntu1~16.04.9) 5.4.0 20160609
Reinstall kernel:
$ sudo apt-get purge linux-headers-4.4.0-116 linux-headers-4.4.0-116-generic linux-image-4.4.0-116-generic linux-image-extra-4.4.0-116-generic linux-signed-image-4.4.0-116-generic
$ sudo apt-get install linux-generic linux-signed-generic
Check nvidia module:
$ modinfo nvidia_xxx -k 4.4.0-116-generic | grep vermagic
vermagic:       4.4.0-116-generic SMP mod_unload modversions retpoline
replace _xxx with your version -- just press TAB after modinfo nvidia
retpoline should be in the output.
After that reboot completed successfully.
If you have compatible gcc version already, you could rebuild nvidia module using dkms command without reinstalling the kernel:
# dkms remove nvidia-xxx/yyy.zzz -k 4.4.0-116-generic
# dkms install nvidia-xxx/yyy.zzz -k 4.4.0-116-generic
I've decided to reinstall the kernel instead to update all modules that were re-built with DKMS using a wrong gcc version.
jfs
  • 4,078
I don't know whether Ask Ubuntu is a correct place for that shit, but — as I need new g++ and still periodically update kernel — I've written a bash-script that (1) purges ppa:ubuntu-toolchain-r/test, (2) rebuilds all DKMS-modules for chosen kernels, (3) installs g++-7 back — per this answer.
The script is provided "as is", without warranties of any kind.
Please, don't use it unless you understand the meaning of every line.
It's intended for saving time when doing things you are able to do manually (not for doing "magic" you don't understand).
The script:
#!/bin/bash -e
for list in /etc/apt/sources.list.d/ubuntu-toolchain-r*.list; do
    sudo cp -a "$list" "$list.backup"
    echo "Backed up $list to $list.backup"
done
readarray -t kernels < <(ls -1 /lib/modules)
echo "Kernels: ${kernels[*]}"
for kernel in "${kernels[@]}"; do
    dkms_modules=($(sudo dkms status -k "$kernel" | sed -r 's#^([^,]+), ([^,]+), .*$#\1/\2#'))
    while true; do
        echo
        read -p "Reinstall DKMS-modules (${dkms_modules[*]}) on kernel $kernel? [Y/n] " choice
        if [ "${choice^^}" = N ]; then continue 2; fi
        if [ "${choice^^}" = Y ] || [ -z "$choice" ]; then break; fi
        echo "Expected 'y', 'n' or '', but got '$choice'"
    done
    echo
    for dkms_module in "${dkms_modules[@]}"; do
        sudo dkms remove -k "$kernel" "$dkms_module"
        sudo dkms install -k "$kernel" "$dkms_module"
    done
    echo
    for module in /lib/modules/"$kernel"/updates/dkms/*.ko; do
        vermagic="$(modinfo -F vermagic $module)"
        echo -n "Vermagic for $(basename ${module%.ko}): $vermagic -- "
        fgrep -q retpoline <<<"$vermagic" && echo ok || echo "'retpoline' is missing!!!"
    done
done
    sudo mv "$list.backup" "$list"
    echo "Restored $list from $list.backup"
done
sudo apt update
sudo apt install g++-7
sudo apt dist-upgrade
Sasha
  • 123
