When I boot Ubuntu or Fedora, they show a black screen with a bunch of [OK] messages for startup processes.
It seems like an old style DOS system. Nowadays, iOS and Windows don't show those terminal-like results. Elementary OS doesn't show it (most of the time) either.
Can I hide them in Ubuntu?
The answer to this question doesn't work in my case because my /etc/default/grub already has GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" but it still shows the boot text.
Output of apt-cache policy plymouth | grep Installed:
Installed: 0.9.2-3ubuntu17
Here's my /etc/default/grub
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi=force"
GRUB_CMDLINE_LINUX=""
Update 7 Mar 18:
After running:
sudo apt-get clean, apt-get autoremove, apt-get update, apt-get upgrade
The result is the same: First Ubuntu boots with the logo and 5 loading dots Then, the screen show these: (a lot of them)
[ OK ] Started CUPS Scheduler.
<more yidi yada>
[ OK ] Started Run anacron jobs.
[ OK ] Started ACPI event daemon.
[ OK ] Started Set the CPU Frequency Scaling governor.
Starting Hold until boot process finishes up... any system changes.pp link was shut down.
Then Ubuntu shows login screen with username.
Also:
$ sudo dpkg-reconfigure -a
[sudo] password for user:
Unknown option: a
Usage: dpkg-reconfigure [options] packages
-u, --unseen-only Show only not yet seen questions.
--default-priority Use default priority instead of low.
--force Force reconfiguration of broken packages.
--no-reload Do not reload templates. (Use with caution.)
-f, --frontend Specify debconf frontend to use.
-p, --priority Specify minimum priority question to show.
--terse Enable terse mode.
$ sudo dpkg-reconfigure plymouth
update-initramfs: deferring update (trigger activated)
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Processing triggers for initramfs-tools (0.125ubuntu12) ...
update-initramfs: Generating /boot/initrd.img-4.13.0-36-generic
