I have strings:
fvvDataFolders/DDB/DDB2018-02-21oM]
fbbDataFolders/DDB/DDB2018-02-22oM]
I want to strip everything that starts with Data and ends in what looks like a date:
DataFolders/DDC/DDB2018-02-22
How I can do it?
Josef Klimuk
  • 1,636
You can use the command grep in this way:
grep -oP 'Data.*[0-9]{4}-[0-9]{2}-[0-9]{2}' input-file > output-file
  • -o, --only-matching - show only the part of a line matching PATTERN.
  • -P, --perl-regexp - PATTERN is a Perl regular expression; or in this case could be used also the option -E, --extended-regexp - PATTERN is an extended regular expression (ERE).
  • the regexp 'Data.*[0-9]{4}-[0-9]{2}-[0-9]{2}' matches to your requirements. It begin with the string Data, followed by unknown number * of any characters ., and ends with the date format: 4 digits from 0 to 9 dash 2 digits from 0 to 9 dash 2 digits from 0 to 9.
Here is also a sed solution:
sed -r 's/^.*(Data.*[0-9]{4}-[0-9]{2}-[0-9]{2}).*$/\1/' /tmp/input-file
  • redirect the output to a new file > output-file or use the option -i.bak to make the changes in their places and create a backup file.
  • -r, --regexp-extended - use extended regular expressions in the script.
  • the command s means substitute: /<string-or-regexp>/<replacement>/.
  • ^.* will match to the beginning ^ of the line, followed by unknown number of any characters.
  • .*$ will match to the end $ of the line, precede by unknown number of any characters.
  • within the the , the capture group (...), will be treated as the variable \1. So the whole line ^.*$ will be substituted by the part that matces to what is in the brackets.
pa4080
  • 30,621
Either
grep -P -o 'Data.+?\d\d\d\d-\d\d-\d\d'
or
perl -pe 's/^.+(Data.+?\d\d\d\d-\d\d-\d\d).+$/$1/'
will do. They both print the minimal string that starts with Data and ends in what looks like a date (YYYY-MM-DD).
echo "fvvDataFolders/DDB/DDB2018-02-21oM]" > input.txt
echo "fbbDataFolders/DDB/DDB2018-02-22oM]" >> input.txt
grep -P -o 'Data.+?\d\d\d\d-\d\d-\d\d' input.txt
# output:
perl -pe 's/^.+(Data.+?\d\d\d\d-\d\d-\d\d).+$/$1/' input.txt
# output:
PerlDuck
  • 13,885
