My laptop stopped showing wifi after i restarted it. I tried restarted network manager but it didn't work. It do not work even after restarting.
lshw -C network Output
  *-network UNCLAIMED
       description: Network controller
       product: RTL8723BE PCIe Wireless Network Adapter
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: cap_list
       configuration: latency=0
       resources: ioport:4000(size=256) memory:94100000-94103fff
  *-network
       description: Ethernet interface
       product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
       physical id: 0
       bus info: pci@0000:04:00.0
       logical name: eno1
       version: 0a
       serial: b0:5a:da:d9:ab:8d
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8107e-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:16 ioport:3000(size=256) memory:94004000-94004fff memory:94000000-94003fff
  *-network
       physical id: 1
       logical name: enp0s20f0u6
       serial: 02:35:66:51:5a:04
       capabilities: ethernet physical
       configuration: broadcast=yes driver=rndis_host driverversion=22-
First of all, from your paste, we see that you have twenty kernel versions installed. It won’t be long until your /boot directory is completely full and then you will be unable to install or remove anything. I suggest that you remove all but three:
sudo apt-get autoremove
Reboot. Is your wireless working now? I doubt that it will be, so please continue.
We are going to remove and then reinstall the driver.
sudo dkms remove rtlwifi-new/0.10 --all
sudo dkms add rtlwifi-new/0.10
sudo dkms build rtlwifi-new/0.10
sudo dkms install rtlwifi-new/0.10
Take note of and post any errors. Test:
sudo modprobe rtl8723be
EDIT: Let’s try a newer version of rtlwifi-new.
Please do:
sudo updatedb
locate rtlwifi_new
Wherever the file was downloaded, Downloads, Desktop or some other, we will remove it:
sudo rm -rf rtlwifi_new
Now we remove the faulty dkms module:
sudo rm -rf /usr/src/rtlwifi*
sudo rm -rf /var/lib/dkms/rtlwifi*
Now we download a newer fresh version:
cd ~
git clone https://github.com/lwfinger/rtlwifi_new.git
sudo dkms add ./rtlwifi_new
sudo dkms build rtlwifi-new/0.6
sudo dkms install rtlwifi-new/0.6
If there are no errors, try to load the module:
Any improvement?
chili555
  • 61,330
