Today I upgraded the Python library matplotlib with the following command:
sudo pip3 install --upgrade matplotlib
Everything looked normal during the installation process. But since then, I experience two problems. One is that pip doesn't work any more. Every pip command evokes the same error message:
Traceback (most recent call last):
File "/usr/local/bin/pip3", line 7, in <module>
from pip import main
File "/usr/local/lib/python3.5/dist-packages/pip/__init__.py", line 26, in <module>
from pip.utils import get_installed_distributions, get_prog
File "/usr/local/lib/python3.5/dist-packages/pip/utils/__init__.py", line 27, in <module>
from pip._vendor import pkg_resources
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 3018, in <module>
@_call_aside
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 3004, in _call_aside
f(*args, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 3046, in _initialize_master_working_set
dist.activate(replace=False)
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 2578, in activate
declare_namespace(pkg)
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 2152, in declare_namespace
_handle_ns(packageName, path_item)
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 2092, in _handle_ns
_rebuild_mod_path(path, packageName, module)
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 2121, in _rebuild_mod_path
orig_path.sort(key=position_in_sys_path)
AttributeError: '_NamespacePath' object has no attribute 'sort
Additionally, Ubuntu's Software Updater stopped working. It looks similar to this problem, only the solution won't work, because, well, pip doesn't work. But I guess, the Software Updater problem will disappear, when the pip problem is solved.
I've tried so far the following commands from threads with similar problems to no avail
sudo apt-get update
sudo apt-get upgrade
sudo apt-get -f install
sudo apt-get install --reinstall aptdaemon
sudo rm -rvf /var/lib/apt/lists/*
sudo apt install --reinstall python3-pip
And obviously no pip command will work, e.g.
sudo pip3 install --upgrade pip setuptools wheel
pip3 install --upgrade setuptools
