I have tried sudo apt remove --purge on various packages. I get the same when I reinstall.
I have also tried reinstall using aptitude. This does not work.
My current workaround is to run pylint3 as root, which works, but is bad practice.
pip3
$ pip3
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
__import__(vendored_name, globals(), locals(), level=0)
ImportError: No module named 'pip._vendor.pkg_resources'
During handling of the above exception, another exception occurred:
File "/usr/bin/pip3", line 9, in <module>
from pip import main
File "/usr/lib/python3/dist-packages/pip/__init__.py", line 13, in <module>
from pip.exceptions import InstallationError, CommandError, PipError
File "/usr/lib/python3/dist-packages/pip/exceptions.py", line 6, in <module>
from pip._vendor.six import iteritems
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 75, in <module>
vendored("pkg_resources")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
File "<frozen importlib._bootstrap>", line 634, in _load_backward_compatible
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2927, in <module>
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2913, in _call_aside
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2952, in _initialize_master_working_set
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 956, in subscribe
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2952, in <lambda>
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2515, in activate
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2097, in declare_namespace
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2047, in _handle_ns
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2066, in _rebuild_mod_path
AttributeError: '_NamespacePath' object has no attribute 'sort'
pylint3
$ pylint3
File "/usr/bin/pylint3", line 3, in <module>
run_pylint()
File "/usr/lib/python3/dist-packages/pylint/__init__.py", line 22, in run_pylint
from pylint.lint import Run
File "/usr/lib/python3/dist-packages/pylint/lint.py", line 44, in <module>
import astroid
File "/usr/lib/python3/dist-packages/astroid/__init__.py", line 54, in <module>
from astroid.nodes import *
File "/usr/lib/python3/dist-packages/astroid/nodes.py", line 54, in <module>
from astroid.scoped_nodes import (
File "/usr/lib/python3/dist-packages/astroid/scoped_nodes.py", line 35, in <module>
from astroid import manager
File "/usr/lib/python3/dist-packages/astroid/manager.py", line 29, in <module>
from astroid import modutils
File "/usr/lib/python3/dist-packages/astroid/modutils.py", line 40, in <module>
import pkg_resources
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2927, in <module>
@_call_aside
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2913, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2952, in _initialize_master_working_set
add_activation_listener(lambda dist: dist.activate())
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 956, in subscribe
callback(dist)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2952, in <lambda>
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2515, in activate
declare_namespace(pkg)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2097, in declare_namespace
_handle_ns(packageName, path_item)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2047, in _handle_ns
_rebuild_mod_path(path, packageName, module)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2066, in _rebuild_mod_path
orig_path.sort(key=position_in_sys_path)
update
This fixed it.
sudo apt remove --purge python3-setuptools
I would love to understand how.
update update I re-installed dependencies that I need. Then the problem cam back.
@Kenavera I am at the newest python3-tools from the repo (according to synaptic python3-tools 20.7.0-1, which seems quite old).
running python3 as me, as pylint3 at root is working. I still would like a better solution.
