Expected Behavior: resuming after standby - it should be possible to restart or shutdown the system by using the menu power button.
Problem: after resuming, choosing restart or shutdown by the menu in upper right corner makes the desktop freeze, showing the wallpaper.
Restart is only possible using ctrl-alt-prtscr. + B or holding power button.
debugging tried: delete "quiet splash" from "GRUB_CMDLINE_LINUX_DEFAULT" in the GRUB config file, updated GRUB & reboot - to see which shutdown messages are displayed.
Result: shutdown messages do not appear as expected, desktop freezes just the same.
This behavior remains the same whether Gnome Shell, Unity or Cinnamon Desktop Environments are being used.
details on CPU & graphics:
Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:5916] (rev 02)
Subsystem: ASUSTeK Computer Inc. Device [1043:1740]
Kernel driver in use: i915
Your help would be kindly appreciated ! Thank you.
