I have Ubuntu 17.10. I live in Finnland so when I started the OP I choised finnish timezone.
But the time is 3 houres ahead. I have to change timezone with someting like: sudo dpkg-configure tmzone to azores (in Atlantic ocean) to get wright time.
To change time zone from terminal, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
sudo dpkg-reconfigure tzdata
Once open, just follow the screens to change the time zone.
neau
Did you check if your UTC is correct? It happened to me once that the UTC was incorrect (there might be various reasons). It is easy to overlook because we just assume the UTC is correct. Type:
timedatectl
And, in many institutions/companies, the NTP servers are blocked so Ubuntu cannot acquire correct UTC, further leading to problems like what you observed.
HongboZhu
  • 597
