Ethernet and WiFi are being shown as unclaimed while running
sudo lshw -C network
[sudo] password for gumby:
*-network UNCLAIMED
    description: Network controller
    product: RTL8188EE Wireless Network Adapter
    vendor: Realtek Semiconductor Co., Ltd.
    physical id: 0
    bus info: pci@0000:02:00.0
    version: 01
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress bus_master cap_list
    configuration: latency=0
    resources: ioport:3000(size=256) memory:f0200000-f0203fff
*-network UNCLAIMED
    description: Ethernet controller
    product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
    physical id: 0
    bus info: pci@0000:05:00.0
    version: 07
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress msix vpd bus_master cap_list
    resources: ioport:2000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff memory:f0010000-f001ffff
booting up in older version
*-network
    description: Wireless interface
    physical id: 0
    logical name: wlo1
    version: 01
    serial: 0c:84:dc:86:d9:70
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
    configuration: broadcast=yes driver=rtl8188ee driverversion=4.13.0-19-generic firmware=N/A ip=10.42.0.1 latency=0 link=yes multicast=yes wireless=IEEE 802.11
    resources: irq:33 ioport:3000(size=256) memory:f0200000-f0203fff
*-network
    description: Ethernet interface
    physical id: 0
    logical name: eno1
    version: 07
    serial: a0:48:1c:0b:29:53
    capacity: 100Mbit/s
    width: 64 bits
    clock: 33MHz
    capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
    configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8106e-1_0.0.1 06/29/12 ip=192.168.1.13 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
    resources: irq:31 ioport:2000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff memory:f0010000-f001ffff
    rfkill list all
    0: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
A.Lfisher
First of all, we see this:
/etc/modprobe.d/iwlwifi.conf line 1: ignoring bad line starting with 'option'
The file now reads:
option iwlwifi 11n_disable=1
The file was erroneously overwritten. It should read:
# /etc/modprobe.d/iwlwifi.conf
# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
# microcode file installed on the system.  When removing iwlwifi, first
# remove the iwl?vm module and then iwlwifi.
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
options iwlwifi 11n_disable=1
Please restore the deleted content and then be certain the term is options with an s.
Next, as you found, when you boot into an earlier kernel version, the ethernet and, I assume, wireless, works as expected. Let's try to reinstall the -32 version.
sudo apt install --reinstall linux-image-4.13.0-32-generic
sudo apt install --reinstall linux-headers-4.13.0-32-generic
Reboot. Is everything working correctly now?
chili555
  • 61,330
