I've just installed Lubuntu 17.10 on my laptop and removed Windows 7. But I can't find my former hard disks (D:\, E:). When I tried Lubuntu without installing ( and deleting the previous os ) I could use my hard disks. But they have disappeared. What can I do?
As @Rinzwind pointed out in comments, you've overwritten your Windows partitions with Lubuntu -- unless you have a backup, all the information that was on the computer is gone. If you have additional physical drives, however, they won't have been touched by the install; you merely need to add entries for them into /etc/fstab so they'll automount when Lubuntu starts. There's documentation available on how to format an fstab entry, and you'll want/need something that will read the UUID from each volume (UUID is strongly preferred over volume label or device notation, as it doesn't change unless the volume is formatted).
- 5,248
First of all, Install a utility such as gparted . It will scan your hard disk and you'll come to know if those partitions exist in the first place or not.
If they exist, select the partition you want , right click and select "Information" There you'll get the "UUID"
Now you'll need to add entries to fstab.. follow this guide HERE
- 1
