How I can add ll alias to ls -l command.
I can not find .bashrc file in my home. I tried to add into .bashrc.user file, but it does not work.
Yaron
  • 13,453
The package bash is installed by default on every Ubuntu version and flavour and contains the file /etc/skel/.bashrc, which is copied into every new user's home directory, so you should definitely have a file ~/.bashrc. If you accidentally removed it you can restore it by copying it again:
cp /etc/skel/.bashrc ~/
The file already by default contains these lines:
# some more ls aliases
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF'
Your alias is available when you source the bashrc with . ~/.bashrc or just open a new session.
dessert
  • 40,956
If the .bashrc file doesn't exist, you can create it in your home :
nano ~/.bashrc
then you can add your alias inside :
alias ll='ls -l'
But as Zanna is suggesting, this is not normal if you don't have this file
Félicien
  • 1,203
You can create .bashrc file in your home directory. $vim ~/.bashrc $alias ll="ls -l" :wq To bring all modification in effect run following command $source .bashrc To see all alias you created run following command $alias
