You can find the files in /var/crash. That's pretty much the whole answer to your question, so to make my answer more interesting I'll show you how I know this, which might interest others who want to test crashing behaviour.
$ cat ~/playground/crash.c
/* crash.c - simple program that crashes by raising a segmentation fault */
#include <signal.h>
int main(void)
raise(SIGSEGV);
The above program was written by Eliah Kagan. I have compiled it into an executable binary file called crash in the same directory (using the command gcc -ansi -pedantic -Wall -Wextra -o crash crash.c). This program reliably segfaults :)
Bash won't itself crash when I run this program, so Apport won't complain, but for interesting reasons discussed at great length in this chat, ksh will itself crash when I use it to call a program that crashes, and Apport will create a report for it. Let's try it!
zanna@toaster:/var/crash$ ksh93
$ /home/zanna/playground/crash
Memory fault(coredump)
$ exit
Segmentation fault (core dumped)
zanna@toaster:/var/crash$ ls
_bin_ksh93.1000.crash
zanna@toaster:/var/crash$ file _bin_ksh93.1000.crash
_bin_ksh93.1000.crash: ASCII text, with very long lines
There you go.
After you make the report, you will get 2 more files here, one ending in .upload and one ending in .uploaded, which may or may not be more readable, but in any case, contain the information sent by Apport.
