I'm not able to login even if the password is correct . Whenever I try to login it accepts the password but returns back to the login screen . Please help
LeonidMew
  • 2,802
Switch to a terminal (ctrl+alt+f4) and try logging in. If you can login normally, you could be out of space (the GUI needs [temporary work] space to create [work] files that are deleted on logout).
Enter df -hl (disk free, human output, local drives only) and check especially for space in your $HOME (/home/user) directory/partition.
If it's full (0 or near 0 bytes free) you need to delete some files, then you can switch back to GUI and you'll find the gui will work. When the gui can't create the needed [temporary] files on login, the gui just returns you to the login screen as you describe without any message.
(there are other alternatives; but less likely in my experience. df -hi to check you inodes free, to gui permissions... but I'd try disk space first..)
guiverc
  • 33,561
At login, press Ctrl+Alt+F1 to switch to text console, and login there. Try following:
sudo dpkg-reconfigure -a
and if its not help, then:
sudo apt-get install --reinstall ubuntu-desktop
Press Ctrl+Alt+F7 and try to login.
LeonidMew
  • 2,802
