I installed Ubuntu 11.10 several months ago, but I haven't found a proper way to enable the touchpad.
I once tried something I can't recall the name.
Does any one have any suggestions?
Update: Here's what cat /usr/share/X11/xorg.conf.d/50-synaptics.conf shows:
# Example xorg.conf.d snippet that assigns the touchpad driver
# to all touchpads. See xorg.conf.d(5) for more information on
# InputClass.
# DO NOT EDIT THIS FILE, your distribution will likely overwrite
# it when updating. Copy (and rename) this file into
# /etc/X11/xorg.conf.d first.
# Additional options may be added in the form of
#   Option "OptionName" "value"
Section "InputClass"
        Identifier "touchpad catchall"
        Driver "synaptics"
        MatchIsTouchpad "on"
# This option is recommend on all Linux systems using evdev, but cannot be
# enabled by default. See the following link for details:
# http://who-t.blogspot.com/2010/11/how-to-ignore-configuration-errors.html
      MatchDevicePath "/dev/input/event*"
EndSection
fossfreedom
  • 174,526
Open the Software Center and search for synaptics, should have a couple of packages that after install should enable your touchpad.
I had the same problem on a Dell Inspiron 1545!
Octavian Helm
  • 14,515
